When coding I prefer editors to replace tabs with spaces as things can get messed up when some developers have tab spaces set to 3 spaces and others set to 4.
Where is the setting in PL/SQL develoepr to use spaces for tabs?
In the preferences, go to user interface/Editor. Under "Tabs & Wrapping", uncheck the "Use tab character". You can also set how many spaces it uses on the "tab size".
