sorting problem
Vadim
NT Server 4.0 SP6 & Oracle 8.1.5 & DOA 3.4.5
on P166 / 96MB RAM computer
In my app I need sorting which I implement through
wwDBGrid's title buttons.
After several successive clicks on title I get an ORA-03113 error.
Seems it happens with all tables or views and needs from 3 to about 5-6
clicks on different columns.
The following is an example sequence:
Select * from USER$ t /* initial opening/
Select * from USER$ t ORDER BY USER# ASC /* normal */
Select * from USER$ t ORDER BY USER# DESC /* normal */
Select * from USER$ t ORDER BY NAME DESC /* ORA-03113 error: end-of-file ... */
The same is true even if for each of above statements dynamically generate
new TOracleDataSet instance (all within single session).
I tried all I could by manipulating with pertaining OracleSession and OracleDataSet
properties but mainly in vain. Though I observed that enabled CountAllRecords
aggravates the situation - crash becomes faster.
Is it a bug or something?
You have probably run into an Oracle Server bug. ORA-03113 usually indicates that the server process has died. Can you mail me the user trace file from the server that corresponds to this error?
Hallo Vadim,
your problem with sorting in oracle i've had too.
The bad Info: There's a bug in oracle
The good Info: There's a solution
You have to insert in Client-Registry in the path
HKEY_LOCAL_MACHINE\SOFTWARE\ORACLE\HOME0
the entry
NLS_SORT = BINARY
and oracle can now sort correctly
IF there are more than 1 HOME's installed, you have to insert this entry in each HOME!
I hope this is the solution for your problem!
Franz Raiber
