Some Problem About 9.0.6.1665 Trial Version
RIDVAN
I just installed PL/Sql Developer on my machine to try the features of it.
I met some problems and i want to share them with you.
1. I installed VCS plugin, and have set the preferences of our Visual Sourcesafe path. And i checked "Automatically open last used project". I closed the program and start again. But the program started to open very slowly. Why?
2. I have added a spec and a body files into our VCS by clicking "Add to VCS". Then I closed PL/Sql developer. My friend opened PL/Sql developer on his machine and locked the spec file i have added. Then i opened the PL/Sql developer and pressed the "Edit Spec&Body" for that file. It asked to check out for the body and i accepted it. Then i closed both package and body. Then i re-pressed "Edit Spec&Body" button, and i realized that i can edit the spec file. But it has been checked out by my friend. So, i think there is a bug. Can you check that case please.
Thank you.
1. When we do not set it to open VCS automatically, the program starts very fast. And also it connects and opens VCS from the menu very fast.
I am talking about 2-3 minutes to connect VCS when it is automatic. Isn't it long time for that?
2. Thanks. How can we get the result of it?
