Hi
I'm delighted with the chart fonction of v3.0.0.241 and looking forward getting it in the command line (any forecast date on that one?)
Besides I noticed a small problem: the template option does not seem to save the Chart/Axis/Labels/Bottom Axis/Angle option. Whatever value I set, it always comes back to 90
Also, is there a way to display another value than x/y values on the chart?
i.e
select a,b,c from table where a=&A
a is master/detail in layout and it would be nice to be able to display it somewhere (title, legend, ..?) or alternatively to display the variable value(s) &A...
Thanks a lot
Eric
i.e
Thanks a lot
Eric
