Small Bug - Test Window context menu
Fairbanks
Test window 'Test Script' and 'DBMS Output' tabs share the same context menu, which can cause confusion. Right-click in DBMS Output tab and the 'Clear' option clears the test script. There's a 'Clear' button on DBMS Output tab's toolbar to clear the output, so I expected the context menu's Clear option to duplicate this.
The 'Insert Template' option on the context menu is disabled in the DBMS Output tab, so there *is* recognition of which tab the context menu's being displayed in.
In the same way, 'Load' has no meaning on this tab.
Please consider reviewing this context menu's display - It's a minor issue but can cause confusion.
Regards,
Jared
