I just started using PL/SQL Developer after using TOAD for a while, and am very impressed with it so far. Not crashing is a good thing
I am attempting to either create a shortcut key to export grid results from a sql query to an Excel file or create a macro that will do the same, but am having no luck. I am constantly exporting data to Excel, and a keyboard shortcut would be really helpful.
I cannot locate the menu command for the keyboard shortcut, and the macro will not record.
Any suggestions?
Any suggestions?
