As Marco said when the forum started, it is to share, so I thought some of my session and browser extender queries might be worthwhile for more people than just me. Let me know if you see issues, or easy improvements for them:
Session queries:
Browser Extender:
Had a few for partitions, which I lost due to a re-image of my machine. Will post those when I have recreated them (Hmm, can I say back-up?)
Hope these are of help to some people.
Hakuna Matata,
Arnoud.
[This message has been edited by aotte (edited 30 May 2003).]
Session queries:
Code:-- Long Operations SELECT TRIM(slo.OPNAME) oprtn_name, TRIM(slo.TARGET) trgt_name, slo.totalwork| |' - '| |slo.sofar| |' = '| |(slo.totalwork-slo.sofar) unts_left, TRIM(slo.units) unts, (slo.ELAPSED_SECONDS+slo.TIME_REMAINING)| |' - '| |slo.ELAPSED_SECONDS| |' = '| |slo.TIME_REMAINING time_left, slo.START_TIME strt_dttm, slo.LAST_UPDATE_TIME last_updt_dttm FROM v$session_longops slo WHERE slo.sid = :sid AND slo.serial# = :serial# AND ( (slo.totalwork-slo.sofar) <> 0 OR slo.START_TIME > (SYSDATE - INTERVAL '1' HOUR) ) ORDER BY strt_dttm DESC -- Parallel degree SELECT COUNT(DISTINCT ps.server_set) srvr_set_cnt, AVG(ps.DEGREE) * COUNT(DISTINCT ps.server_set) dgr_rcvd_cnt, AVG(ps.req_degree) * COUNT(DISTINCT ps.server_set) dgr_rqstd_cnt FROM gv$px_session ps WHERE ps.qcsid = :sid AND ps.qcserial# = :serial# -- Parallel Slaves SELECT s.sid sssn_id, s.username usr_name, s.osuser os_usr, ps.server_group srvr_grp, ps.server_set srvr_set, ps.server# srvr#, s.logon_time lgn_time FROM gv$px_session ps, v$session s WHERE ps.qcsid = :sid AND ps.sid = s.sid AND ps.qcsid <> ps.sid ORDER BY s.sid -- Temp space usage SELECT su.TABLESPACE tbl_spc, SUM(su.EXTENTS) extnt_cnt, SUM(su.EXTENTS)*32 mb_dsk_spc_cnt, ROUND(SUM(su.EXTENTS)*32/1024,2) gb_dsk_spc_cnt FROM v$sort_usage su WHERE su.session_addr = :saddr AND su.CONTENTS = 'TEMPORARY' GROUP BY su.TABLESPACE
Browser Extender:
Code:PL/SQL Developer Browser Extender Command [MAIN] NAME=Gather Statistics CAPTION=Last analyzed on #field_0 OTYPE=Index,Table,User OOWNER=% ONAME=% SEPARATOR_ABOVE=N SEPARATOR_BELOW=Y LOAD_AND_EXECUTE=Y LOAD_COMMAND=Y LOAD_AFTER=REPLACE LOAD_WIN_TYPE=1 PRIVILEGE_REQ=N PRIVILEGE="ANALYZE ANY" ORACLE_VERSION_REQ=N ORACLE_VERSION=7.0.0 ONCLICK_CONFIRM=N ONCLICK_CONFIRM_MSG= ONCLICK_SPLASH=N ONCLICK_SPLASH_MSG=Analyzing #otype #object... ONCLICK_SPLASH_MSG_BL=Y ONCLICK_SPLASH_MSG_AFTER=Done. ONCLICK_SPLASH_DELAY=2 ONCLICK_IGNORE_EXCEPTIONS=N ONPOPUP_IGNORE_EXCEPTIONS=N [ONCLICK] DECLARE -- Let the browser extender tell us what we are doing c_object_type_name CONSTANT VARCHAR2(30) := '#otype'; c_qualified_object_name CONSTANT VARCHAR2(61) := '#object'; c_object_owner CONSTANT VARCHAR2(30) := '#oowner'; c_object_name CONSTANT VARCHAR2(30) := '#oname'; c_user_name CONSTANT VARCHAR2(30) := '#username'; c_caption CONSTANT VARCHAR2(32767) := '#caption'; -- Browser Extender supported object types c_object_index CONSTANT VARCHAR2(30) := 'INDEX'; c_object_table CONSTANT VARCHAR2(30) := 'TABLE'; c_object_user CONSTANT VARCHAR2(30) := 'USER'; -- Some generic constants c_module_name CONSTANT VARCHAR2(42) := 'BE Analyze '| |c_object_type_name; c_action_name CONSTANT VARCHAR2(32) := SUBSTR(c_qualified_object_name,1,32); -- Statistics specific constants c_estimate_percent CONSTANT NUMBER := 10; c_cascade CONSTANT BOOLEAN := TRUE; c_degree CONSTANT NUMBER := 4; BEGIN -- Show people what we are doing DBMS_APPLICATION_INFO.SET_MODULE(c_module_name,c_action_name); CASE c_object_type_name WHEN c_object_table THEN DBMS_STATS.GATHER_TABLE_STATS( OWNNAME => c_object_owner, TABNAME => c_object_name, ESTIMATE_PERCENT => c_estimate_percent, CASCADE => c_cascade, DEGREE => c_degree); WHEN c_object_index THEN DBMS_STATS.GATHER_INDEX_STATS( OWNNAME => c_object_owner, INDNAME => c_object_name, ESTIMATE_PERCENT => c_estimate_percent, DEGREE => c_degree); WHEN c_object_user THEN DBMS_STATS.GATHER_SCHEMA_STATS( OWNNAME => c_object_name, -- A sample percentage of at least 1, but half of what -- is done for individual objects ESTIMATE_PERCENT => ROUND(c_estimate_percent/2,0)+1, CASCADE => c_cascade, DEGREE => c_degree); ELSE RAISE NO_DATA_FOUND; END CASE; END; [ONPOPUP] SELECT NVL(TO_CHAR(last_analyzed,'YYYYMMDD@HH24MI'),'Sint Juttemis') field_0 FROM sys.all_tables all_tbl WHERE all_tbl.owner = '#oowner' AND all_tbl.table_name = '#oname' AND '#otype' = 'TABLE' UNION SELECT NVL(TO_CHAR(last_analyzed,'YYYYMMDD@HH24MI'),'Sint Juttemis') field_0 FROM sys.all_indexes all_idx WHERE all_idx.owner = '#oowner' AND all_idx.index_name = '#oname' AND '#otype' = 'INDEX' UNION SELECT NVL(TO_CHAR(MAX(last_analyzed),'YYYYMMDD@HH24MI'),'Sint Juttemis') field_0 FROM sys.all_tables all_tbl WHERE all_tbl.owner = '#oowner' AND '#otype' = 'USER'
Hakuna Matata,
Arnoud.
