Settings question
cct
Having to reinstall my Laptop, despite saving/restoring settings etc, I lost most of them.
One setting I cannot find is the case of tables/fields from the Code assistant. Previously against an 11G DB if I gave an initial capital, the whole field was pasted in upper case, which is our preference. However it now insists tat everything pasted in is in lower case. I previously had it worked to my tatse, so what have I missed?
This is 12.0.7 under Win 7 and/or under Win Server 2008 R2
Chris
Thanks, but that doesnt work for me, as I never use the Beautifier - cannot get it anywhere near our rules.
Chris
I'm not certain. You might try preferences / user interface / code assistant / Use original case if possible.
Thanks, that was nearly there. I had that set, but had left Smart as the coding style. Changed to Uppercase, with Original selected and it woks.
Thanks very much!
Chris
