Setting TOracleQuery's clob variable before exec?
soli
Hi All,
mu question is: I need to use in my TOracleQuery (update) a variable of kind otClob. I can't figure out, how I can set its value. I have a TMemoryStream with the data I should somehow insert into the destination table.
I'm sure that this is possible, but how?
Thanks in advance,
Soli
You can't set the CLOB data in an update statement. You need to obtain a LOB Locator for this CLOB column and lock the record, and use the LOB Locator to write the data. A LOB Locator is encapsulated in the TLOBLocator class, which is a TStream descendant. Writing the contents of a TMemoryStream is therefore very straightforward.
var LOB: TLOBLocator;
  // update lobtable
  //   set lobcolumn = empty_clob()
  //   where id = :id
  //   returning lobcolumn into :lobvar
  with LOBQuery do
    SetVariable('id', 1);
    // Create a new BLOB (initially Null)
    LOB := TLOBLocator.Create(Session, otCLOB);
    // Assign it to the returning variable
    SetComplexVariable('lobvar', LOB);
    Execute;
    // After the update, use the LOB Locator to write the data
    LOB.CopyFrom(MyMemoryStream, 0);
    LOB.Free;
    // Commit the update
    Session.Commit;
This example first updates the CLOB column to make it empty, which also locks the record and returns an initialized LOB Locator. Next the new data is written and committed.
