"Set Bookmark" shortcut key doesn't work
Robo Tron
Hi!
Support info:
PL/SQL Developer
  Version 10.0.5.1710
I mapped "Alt + B" to "Set Bookmark" command, but it doesn't add the bookmark. Could you please look into this?
With regards,
robotron1000
You need to follow Alt-B by the bookmark number (0..9). You need to release the Alt-key before pressing the 0..9 key.
When I open the Edit menu, it says "Alt+B n", but I couldn't decipher the meaning.
Thanks.
