here is my debug.txt
PL/SQL Developer
  Version 8.0.4.1514
  Physical memory : 4,194,304 kB  (4,194,304 available)
  Paging file     : 4,194,304 kB  (4,194,304 available)
  Virtual memory  : 2,097,024 kB  (1,968,444 available)
Parameters
  F:\plsql_dev\plsqldev.exe
  DebugSQL
Preferences
  Session mode: Multi
  OCI Library:
  Use OCI7: False
Preference Files
Plug-Ins
2013/4/23 9:08:00  Application started
2013/4/23 9:08:00  InitPreferences
2013/4/23 9:08:00  Load F:\plsql_dev\Preferences\Default = 0
2013/4/23 9:08:00  PreferenceSet.Load F:\plsql_dev\Preferences\Default\Default.ini
2013/4/23 9:08:00  PreferenceSet.Load OK
2013/4/23 9:08:00  Determine LocalPrefPath
2013/4/23 9:08:00  [1]: C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences
2013/4/23 9:08:00  LocalPrefPath: C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences\cmhit
2013/4/23 9:08:00  Load C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences\cmhit = 0
2013/4/23 9:08:00  PreferenceSet.Load C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences\cmhit\default.ini
2013/4/23 9:08:00  PreferenceSet.Load C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences\cmhit\user.prefs
2013/4/23 9:08:00  InitPreferences end
2013/4/23 9:08:00  SortPreferenceSets
2013/4/23 9:08:00   - Default cmhit
2013/4/23 9:08:00   - System Default
2013/4/23 9:08:00  pfReadRegistry(PL/SQL Developer\Shell\Open\Command, )
2013/4/23 9:08:00  ReadString OK
2013/4/23 9:08:00  pfReadRegistry: "F:\plsql_dev\PLSQLDev.exe" "%1"
2013/4/23 9:08:00  LoadPreferences
2013/4/23 9:08:00  LoadPreferences searching for default
2013/4/23 9:08:00    C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences\cmhit\default.ini
2013/4/23 9:08:00  LoadPreferences NewPref := nil
2013/4/23 9:08:00  LoadPreferences Reading preferences
2013/4/23 9:08:00  LoadPreferences ReadPosition
2013/4/23 9:08:00  LoadPreferences ToolsBrowserItemClick(nil)
2013/4/23 9:08:00  LoadPreferences CreateBrowserFilters...
2013/4/23 9:08:00  LoadPreferences Files
2013/4/23 9:08:00  LoadPreferences Logon
2013/4/23 9:08:00  LoadPreferences Buttons
2013/4/23 9:08:00  LoadPreferences Printer
2013/4/23 9:08:00  LoadPreferences FileBrowserFolders
2013/4/23 9:08:00  LoadPreferences BrowserFolders
2013/4/23 9:08:00  LoadPreferences end
2013/4/23 9:08:00  MacroLibFilename: F:\plsql_dev\Macro\cmhit.emlib
2013/4/23 9:08:00  FormCreate Logon.Execute
2013/4/23 9:08:06  TOracleSession PLSQLDevForm.Session Start Session.LogOn as ctos@ctos_dev
2013/4/23 9:08:06  TOracleQuery BytesPerCharacterQuery Start Query.Execute
                   SQL = select length(chr(2000000000)) l4, length(chr(2000000)) l3,  length(chr(20000)) l2, 'c' c1 from dual
2013/4/23 9:08:06  TOracleQuery BytesPerCharacterQuery End  (1 record processed)
                   Duration = 0
                   Duration = 0
2013/4/23 9:08:06  TOracleQuery Query Start Query.Execute
2013/4/23 9:08:06  TOracleQuery Query End  (1 record processed)
                   Duration = 0
2013/4/23 9:08:06  TOracleSession PLSQLDevForm.Session End
                   Duration = 0.156
2013/4/23 9:08:06  LogonHistorySave start
2013/4/23 9:08:06  ChangeUserPref LogonHistory,
2013/4/23 9:08:06  ChangeUserPref end
2013/4/23 9:08:06  ChangeUserPref DSA,
2013/4/23 9:08:06  ChangeUserPref ColumnAssociations,
2013/4/23 9:08:06  ChangeUserPref ImportAssociations,
2013/4/23 9:08:06  ChangeUserPref BrowserFilters,
2013/4/23 9:08:06  ChangeUserPref FileBrowserFolders,
2013/4/23 9:08:06  ChangeUserPref BrowserFolders,
2013/4/23 9:08:06  ChangeUserPref SessionQueries,
2013/4/23 9:08:06  ChangeUserPref ExternalTools,
2013/4/23 9:08:06  ChangeUserPref Documents,
2013/4/23 9:08:06  ChangeUserPref Reports,
2013/4/23 9:08:06  PreferenceSet.Save
2013/4/23 9:08:06  PreferenceSet Filename = C:\Users\cmhit\AppData\Roaming\PLSQL Developer\Preferences\cmhit\user.prefs
2013/4/23 9:08:06  PreferenceSet AltFile = user.prefs
2013/4/23 9:08:06  PreferenceSet.Save end
2013/4/23 9:08:06  LogonHistorySave end
2013/4/23 9:08:06  FormCreate Session.Connected
2013/4/23 9:08:06  FormCreate Logon.Executed -1
2013/4/23 9:08:06  FormCreate TDBNames.Make
2013/4/23 9:08:06  FormCreate SessionChanged
                   SQL = select * from v$version
2013/4/23 9:08:06  TOracleQuery Query End  (5 records processed)
                   Duration = 0
2013/4/23 9:08:06  SessionChanged SetDBAViews
2013/4/23 9:08:06  TOracleQuery $02B4D6D0 Start Query.Execute
2013/4/23 9:08:06  TOracleQuery $02B4D6D0 End  (0 records processed)
                   Duration = 0.016
                   Duration = 0
2013/4/23 9:08:06  SessionChanged Authorizations.Load
                   sys.plsqldev_authorization
                   Duration = 0
2013/4/23 9:08:06  SessionChanged EnableAuthorizedMenus
2013/4/23 9:08:06  ExecuteConnectScript starts
                   SQL = alter session set plsql_optimize_level = 2
                   Duration = 0
                   SQL = alter session set plsql_code_type = interpreted
                   Duration = 0.016
                   SQL = alter session set plscope_settings = 'identifiers:none'
                   Duration = 0
2013/4/23 9:08:06  ExecuteConnectScript ends
2013/4/23 9:08:06  TOracleQuery $02B4D6D0 End  (1 record processed)
                   Duration = 0
2013/4/23 9:08:06  TOracleSession $0564D230 Start Session.LogOn as ctos@ctos_dev
2013/4/23 9:08:07  TOracleQuery Query Start Query.Execute
2013/4/23 9:08:07  TOracleQuery Query End  (1 record processed)
                   Duration = 0.016
2013/4/23 9:08:07  TOracleSession $0564D230 End
                   Duration = 0.062
2013/4/23 9:08:07  SetSessionAction starts: Main session
2013/4/23 9:08:07  TOracleQuery $02B4D990 Start Query.Execute
                   SQL = select null from dual
2013/4/23 9:08:07  TOracleQuery BytesPerCharacterQuery Start Query.Execute
2013/4/23 9:08:07  TOracleQuery $02B4D990 End  (1 record processed)
                   Duration = 0
                   :ACTION = Main session
2013/4/23 9:08:07  TOracleQuery BytesPerCharacterQuery End  (1 record processed)
                   Duration = 0
                   Duration = 0
2013/4/23 9:08:07  SetSessionAction ends
2013/4/23 9:08:07  TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
                   Duration = 0
2013/4/23 9:08:07  TOracleQuery $02B4D830 Start Query.Execute
                   from sys.all_objects o
                   where o.owner = :schema and o.object_type in ('TABLE', 'VIEW', 'PACKAGE','TYPE', 'PROCEDURE', 'FUNCTION', 'SEQUENCE')
                   :SCHEMA = CTOS
2013/4/23 9:08:07  TOracleQuery PLSQLDevForm.DynamicQuery End  (1 record processed)
                   Duration = 0
2013/4/23 9:08:07  TOracleQuery $02B4D830 End  (100 records processed)
                   Duration = 0.016
2013/4/23 9:08:07  TOracleQuery $02B4D830 Start Query.Next for up to 100 records
                   Duration = 0
2013/4/23 9:08:07  SessionChanged LoadRecentObjects
2013/4/23 9:08:07  SessionChanged Notify children
2013/4/23 9:08:07  SessionChanged Logoff secondary sessions
2013/4/23 9:08:07  SessionChanged SessionMode = smMulti
2013/4/23 9:08:07  SessionChanged EnableChildFunctions
                   OCIDLL forced to F:\oracle_related\instantclient\oci.dll
                   SQL = select value from sys.nls_database_parameters where parameter = 'NLS_CHARACTERSET'
                   Duration = 0.015
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0.016
2013/4/23 9:08:07  TOracleQuery $02B4D830 End  (30 records processed)
                   Duration = 0
                   from all_synonyms s,
                        sys.all_objects o
                   where s.owner in ('PUBLIC', :schema)
                   and o.owner = s.table_owner
                   :SCHEMA = CTOS
2013/4/23 9:08:07  SortPreferenceSets
2013/4/23 9:08:07   - Default cmhit
2013/4/23 9:08:07   - System Default
2013/4/23 9:08:07  TOracleQuery $02B4D990 End  (0 records processed)
                   Duration = 0
                   Duration = 0
2013/4/23 9:08:07  FormActivate start
2013/4/23 9:08:07  FormActivate end
2013/4/23 9:08:07  WMUpdatePopups starts
2013/4/23 9:08:07  LoadDesktop starts
2013/4/23 9:08:07  DoUpdateChildList
2013/4/23 9:08:07  LoadDesktop ends
2013/4/23 9:08:07  Create TSQLForm Start
2013/4/23 9:08:07  Create TSQLForm Inherited
2013/4/23 9:08:07  TSQLForm.FormCreate Start
2013/4/23 9:08:07  SQLForm
2013/4/23 9:08:07  TSQLForm.FormCreate Finished
2013/4/23 9:08:07  Create TSQLForm SetupMainFont
2013/4/23 9:08:07  Create TSQLForm Activate
2013/4/23 9:08:07  Create TSQLForm Activate done
2013/4/23 9:08:07  Create TSQLForm UpdateWindowList
2013/4/23 9:08:07  UpdateChildList [timer]
2013/4/23 9:08:07  Create TSQLForm Positioning
2013/4/23 9:08:07  Create TSQLForm Finished
2013/4/23 9:08:07  NavigationBookmarks.EnableButtons(Rebuild)
2013/4/23 9:08:07  NavigationBookmarks: Backward=0, Forward=0
2013/4/23 9:08:07  WMUpdatePopups ends
2013/4/23 9:08:08  TOracleQuery $02B4D830 End  (100 records processed)
                   Duration = 1.263
2013/4/23 9:08:08  TOracleQuery $02B4D830 Start Query.Next for up to 100 records
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0.016
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0.015
                   Duration = 0.016
                   Duration = 0
                   Duration = 0.015
                   Duration = 0.016
                   Duration = 0
                   Duration = 0
                   Duration = 0.031
                   Duration = 0.016
                   Duration = 0.015
                   Duration = 0.016
                   Duration = 0
                   Duration = 0
                   Duration = 0.031
                   Duration = 0
                   Duration = 0.015
                   Duration = 0.047
                   Duration = 0.031
                   Duration = 0
2013/4/23 9:08:10  TOracleQuery $02B4D830 End  (100 records processed)
                   Duration = 1.576
2013/4/23 9:08:10  TOracleQuery $02B4D830 Start Query.Next for up to 100 records
                   Duration = 0.015
                   Duration = 0.031
                   Duration = 0.141
                   Duration = 0
                   Duration = 0
                   Duration = 0.047
                   Duration = 0.016
                   Duration = 0
                   Duration = 0
                   Duration = 0.031
                   Duration = 0
                   Duration = 0
                   Duration = 0.016
                   Duration = 0.015
                   Duration = 0
                   Duration = 0.016
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0.015
2013/4/23 9:08:10  TOracleQuery $02B4D830 End  (52 records processed)
                   Duration = 0
2013/4/23 9:08:10  TOracleQuery $02B4D830 Start Query.Execute
                   SQL = select db_link as object_name, 'DATABASE LINK' as object_type
                   from sys.all_db_links o
                   where o.owner = :schema or o.owner = 'PUBLIC'
                   :SCHEMA = CTOS
2013/4/23 9:08:10  TOracleQuery $02B4D830 End  (1 record processed)
                   Duration = 0
2013/4/23 9:08:10  TOracleSession $0564D230 Start Session.LogOff
2013/4/23 9:08:10  TOracleSession $0564D230 End
                   Duration = 0.016
2013/4/23 9:08:20  NavigationBookmarks.EnableButtons(Rebuild)
2013/4/23 9:08:20  NavigationBookmarks: Backward=0, Forward=0
2013/4/23 9:08:51  NavigationBookmarks.EnableButtons(Rebuild)
2013/4/23 9:08:51  NavigationBookmarks: Backward=0, Forward=0
2013/4/23 9:08:56  EditCopy
2013/4/23 9:08:56  Screen.ActiveCustomForm EditCopy
2013/4/23 9:08:56  ChildForm.EditCopy
2013/4/23 9:09:21  NavigationBookmarks.EnableButtons(Rebuild)
2013/4/23 9:09:21  NavigationBookmarks: Backward=0, Forward=0
2013/4/23 9:09:22  EditCopy
2013/4/23 9:09:22  Screen.ActiveCustomForm EditCopy
2013/4/23 9:09:22  ChildForm.EditCopy
2013/4/23 9:09:23  SQLForm Initializing...
2013/4/23 9:09:23  SetConnected starts
2013/4/23 9:09:23  SetConnected: Connect starts
2013/4/23 9:09:23  TOracleSession $0564FC30 Start Session.LogOn as ctos@ctos_dev
2013/4/23 9:09:23  TOracleQuery Query Start Query.Execute
2013/4/23 9:09:23  TOracleQuery Query End  (1 record processed)
                   Duration = 0
2013/4/23 9:09:23  TOracleSession $0564FC30 End
                   Duration = 0.063
2013/4/23 9:09:23  SetConnected: (Dis)connect ends
2013/4/23 9:09:23  SetSessionAction starts: SQL Window - New
2013/4/23 9:09:23  TOracleQuery $02B4CFF0 Start Query.Execute
2013/4/23 9:09:23  TOracleQuery $02B4CFF0 End  (1 record processed)
                   Duration = 0
2013/4/23 9:09:23  TOracleQuery BytesPerCharacterQuery Start Query.Execute
2013/4/23 9:09:23  TOracleQuery BytesPerCharacterQuery End  (1 record processed)
                   Duration = 0
                   Duration = 0
                   :ACTION = SQL Window - New
                   Duration = 0
2013/4/23 9:09:23  SetSessionAction ends
2013/4/23 9:09:23  ExecuteConnectScript starts
                   Duration = 0.015
                   Duration = 0
                   Duration = 0
2013/4/23 9:09:23  ExecuteConnectScript ends
                   Duration = 0
2013/4/23 9:09:23  EnableOutput starts
2013/4/23 9:09:23  TOracleQuery PLSQLDevForm.EnableOutputQuery Start Query.Execute
                   SQL = begin
                     if :enable = 0 then
                       sys.dbms_output.disable;
                     else
                       sys.dbms_output.enable
size);
                     end if;
                   :ENABLE = 1
                   :SIZE = 10000
2013/4/23 9:09:23  TOracleQuery PLSQLDevForm.EnableOutputQuery End
                   Duration = 0
2013/4/23 9:09:23  EnableOutput done
2013/4/23 9:09:23  InitStatistics starts
2013/4/23 9:09:23  TStatistics.Init starts
2013/4/23 9:09:23  InitStatNames starts
2013/4/23 9:09:23  select name from v$statname order by statistic#
2013/4/23 9:09:23  TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Execute
                   SQL = select name from v$statname order by statistic#
2013/4/23 9:09:23  TOracleQuery PLSQLDevForm.DynamicQuery End  (25 records processed)
                   Duration = 0
2013/4/23 9:09:23  TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Next for up to 25 records
                   Duration = 0
                   Duration = 0
                   Duration = 0
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.DynamicQuery End  (25 records processed)
                   Duration = 0
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.DynamicQuery Start Query.Next for up to 25 records
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0.015
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0
                   Duration = 0.016
                   Duration = 0
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.DynamicQuery End  (13 records processed)
                   Duration = 0
2013/4/23 9:09:24  InitStatNames ends
2013/4/23 9:09:24  StatQuery.Describe starts
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.StatQuery Start Query.Describe
                   SQL = select value from v$sesstat where sid = :sid order by statistic#
                   :SID = Null
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.StatQuery End
                   Duration = 0
2013/4/23 9:09:24  StatQuery.Describe ends
2013/4/23 9:09:24  TStatistics.Init ends
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.StatQuery Start Query.Execute
                   :SID = 867
2013/4/23 9:09:24  TOracleQuery PLSQLDevForm.StatQuery End  (638 records processed)
                   Duration = 0
2013/4/23 9:09:24  InitStatistics ends
2013/4/23 9:09:24  SQL Window Height = 678
2013/4/23 9:09:24  SQL Grid Height   = 548
2013/4/23 9:09:24  SQL Panel Height  = 130
2013/4/23 9:09:24  NavigationBookmarks.EnableButtons(Rebuild)
2013/4/23 9:09:24  NavigationBookmarks: Backward=0, Forward=0
2013/4/23 9:09:24  SQLForm Executing...
2013/4/23 9:09:24  TSQLThread SQLThread.Execute
2013/4/23 9:09:24  TOracleQuery Query Start Query.Execute
                   :ID = Null
2013/4/23 9:09:24  TOracleQuery Query End
                   Duration = 0
2013/4/23 9:09:24  TOracleQuery $02B4D2B0 Start Query.Execute
                   SQL = WITH v AS
                    (SELECT SYSDATE d FROM dual)
                   SELECT * FROM v
2013/4/23 9:09:24  TOracleQuery $02B4D2B0 End  (1 record processed)
                   Duration = 0
2013/4/23 9:09:24  TOracleQuery SQLForm.TestQuery Start Query.Describe
                   SQL = SELECT * FROM v
2013/4/23 9:09:24  TOracleQuery SQLForm.TestQuery End
                   Result = ORA-04044: procedure, function, package, or type is not allowed here
                   Duration = 0
                   :ID = Null
                   Duration = 0
2013/4/23 9:09:24  TSQLThread SQLThread Postmessage
2013/4/23 9:09:24  TSQLThread SQLThread Suspend
2013/4/23 9:09:24  TSQLForm.ThreadFinished
2013/4/23 9:09:24  TSQLForm.ThreadFinished: SQLThread.Suspended
2013/4/23 9:09:24  SQLForm 1 row selected in 0.031 seconds
                   :SID = 867
                   Duration = 0.016
2013/4/23 9:09:24  TOracleQuery $02B4D150 Start Query.Execute
                   SQL = begin
                   :LINE = Null
                   :STATUS = Null
2013/4/23 9:09:24  TOracleQuery $02B4D150 End
                   Duration = 0
