Theod Member³ Nov 17, 2008 #1 Hi, it's the same for projects or reports!!. If you use connect parameters and store also the password, the password is encrypted => ok. But you can copy and paste the encrypted-string to other projects or reports and get access.
Marco Kalter Administrator Staff member Nov 17, 2008 #1 That is indeed correct. Others can also connect with PL/SQL Developer and change your password through an "alter user identified by ..." command. Do not store the password if security is an issue.
Theod Member³ Nov 17, 2008 #1 Hi, that means, if I give an Report with an stored password away so I have to lock the whole report to enctrypt the full textfile.
