SDO_GEOMETRY
Hello
If I try a select on a view which contains sdo_geometry in nested types pl/sql developer returns with a ORA-04043: object SDO_GEOMETRY does not exist.
If I do the same on sqldeveloper from oracle it works.
Is this not possible in pl/sql developer?
Regards,
Patrick
