scan sql
misuk11
i have TOracleQuery component pointing to an oracle package. There are multiple variables (both in and out) as below
p_p_id IN INT,
p_source IN INT,
p_title OUT prg.epg_title%TYPE,
p_desc OUT prg.epg_description%TYPE,
p_group OUT prg.grouped_flag%TYPE,
p_type OUT INT,
p_ppv_desc OUT prg.epg_ppv_description%TYPE,
p_sound OUT prg.epg_sound_type%TYPE,
p_cert OUT object_external_references.external_reference%TYPE,
p_genre OUT object_external_references.external_reference%TYPE,
p_ca OUT prg.epg_ca_template%TYPE,
p_new_show OUT prg.epg_new_show_flag%TYPE,
p_critics OUT prg.epg_critics_choice_flag%TYPE,
p_sort OUT prg.epg_sort_title%TYPE,
p_si_desc OUT VARCHAR2,
p_nib_1 OUT object_external_references.external_reference%TYPE,
p_nib_2 OUT object_external_references.external_reference%TYPE,
p_nib_3 OUT object_external_references.external_reference%TYPE,
p_nib_4 OUT object_external_references.external_reference%TYPE,
p_si_ca OUT prg.si_ca_mode_flag%TYPE,
p_si_cert OUT object_external_references.external_reference%TYPE);
the SQL in the TOracle componet is as follows
C2_EPG.sp_check_epg_prog(
:p_p_id,
:p_source,
:p_title,
:p_desc,
:p_group,
:p_type,
:p_ppv_desc,
:p_sound,
:p_cert,
:p_genre,
:p_ca,
:p_new_show,
:p_critics,
:p_sort,
:p_si_desc,
:p_nib_1,
:p_nib_2,
:p_nib_3,
:p_nib_4,
:p_si_ca,
:p_si_cert);
END;
when i scan the sql in the vriable editor, all the variables are shown as strings when clearly some are integers, numbers, etc. is this by design or am i doing something wrong ?
tia
mark
This is by design. The scan function does not attempt to determine the variable types, and declares them as string by default. You will have to override the data types.
