saving to CLOB field not working
David S
I've got some TMS DB-aware components, including TDBAdvMemo, that are tied to a bunch of DB fields in TOracleDataSet components.
Some of these memos are tied to varchar2 fields, and one is tied to a CLOB field.
If I set the dataset into Edit mode, I can edit content in all of the controls except the one tied to a CLOB gets cleared instead of being saved.
I'm not getting an kind of error message.
Am I doing something wrong? A setting I may be overlooking?
select ds.rowid, ds.* from table1_datasets ds
There are a dozen fields in this table. When I put the dataset into Edit mode, they all save fine except the CLOB that was just added. Why is the CLOB not being saved?
This is really strange. I have a pre-process step that initializes a bunch of fields in the tables. I set this CLOB field to show a line of text as the first line.
It shows up in every record when I'm scrolling through the table, as expected.
But again, when I go into Edit mode and then set theMemo.Lines.Text := 'some more text', it shows up initially.
But when I do the Post, it's reverted to the original field contents.
I'm really puzzled.
This is indeed puzzling. Can you check if it works correctly if you replace the TDBAdvMemo with a TDBMemo?
