Saving Diagrams
Thomas Keck
Is it possible to save the contents and layout of diagrams in PL/SQL-Developer 7?
Can the diagrams be printed?
Can I change diagrams after I have saved them once?
Yes. Just press the "Save" button on the toolbar (or select File > Save from the menu).
Just press the "Print" button on the toolbar (or select File > Print from the menu).
After a file is saved you can open it later (File > Open) and continue to work with it.
