save separate features
Daniele
Hi, anyone know how to add code at the end of package (header or body) when it is saved?
Like the slash that is automatically inserted.
There is a plugin that do this?
This isn't what you asked for, but I change it in the beginning instead of when I save. I added templates in the "Program units" called "My Package" and "My Body" and set them up to our coding standards. I open these from the menu when I create a program. At the end I have:
SHOW ERRORS;
This creates a separate tab that doesn't compile, so checked the "Ignore unrecognized PL/SQL" preference in the Program Window preferences.
