Save QBE Values not working
Jorge Cano
if I unselect the save QBE Values on OracleDataSet it won't work, if I go into QBE and create a criteria, next time I go in QBE it will remember the last used values.
Any ideas?
I'm using DOA 4.0.6.2 on Delphi 2005
When AllowOperators = True this does indeed not work correctly. We'll fix it.
You could use the following BeforeAction event handler as a work around in the mean time:
procedure TMainForm.OracleNavigatorBeforeAction(Sender: TObject;
  Button: TOracleNavigateBtn);
  if Button = nbEnterQBE then
    TOracleDataSet(TOracleNavigator(Sender).DataSource.DataSet).ToggleQBEValues;
Thanks, it works but I still have a problem with Date/Time fields, the second time I go into QBE mode I get an error message saying 0.0 is not a valid Date/Time, even tough I did not write anything in that field.
I tried to reproduce this with the EmpDataSet of the DeptEmp demo, but all works fine. Can you try this too?
Hi Marco, I think I finally got the scenario where you have this problem.
If you use persistent fields, and set the allowoperators to true, (keep saveqbevalues to false) when you enter QBEMode for the second time it will remember the value.
I think your TQBEField.GetText handler is not taking SaveQBEValues into account.
Thanks.
Any news on this, I found that even if you don't use persistent field you can get the problem.
it all depends on the AllowOperators property, if you set it to true the data set will remember the previous criteria
Sorry, I missed this. It seems that if AllowOperators = True, the SaveQBEValues property value is ignored and is always True. We'll fix it. If you need a pre-release, let me know.
