Safe Compilation (using temporary compilation object) - Setting
The above option comes in really handy when compiling against a live system. I know we shouldn't, but that's not the point.
Packages, functions, procedures - if I make a mistake, it isn't rolled out into general usage because the compilation is against a temporary object created only at the time of compilation. Great!
One niggle I have, is that the very same applies to triggers. Whether my code fails or not, it creates a new version of the trigger to compile against. That means I have two or mode (depending how many times i've compiled) identical triggers firing and possibly doing a job for as many times as there are triggers against it.
It would be great if this feature also dropped the object afterwards - that way it saves the ever growing list of owner.P$blah objects, and stops the trigger issue in it's tracks.
Matt.
PL/SQL Developer
Version 11.0.6.1776
01.105297 - 5 user license
Service Contract: 01/01/2019
Windows 7 (64-bit) Build 7601 (Service Pack 1)
The temporary trigger (and any other program unit type) should be dropped afterwards. Regardless whether the compilation succeeds or not. We'll check it out.
Lovely, thanks.
In the meantime i've created a oracle job that runs fairly regularly to sweep these up.
Thankfully they all start with P$...
