Running under opensuse/wine
frareinif
installed PSD w/o problems in a wine env, and then? To connect to (remote) db's I have to install ORA instant client, that's right? After downloading and installing it into a subdir to "programs", I adjusted "PATH" in "system.reg". Running PSD it again got stuck at "Logging on...".
Any hints?
Thank you and regards
Originally posted by Marco Kalter:
You can install an Instant Client or a full client.
Does SQL*Plus work correctly?
Because of lacking experience, my way of installing it was o.k.? Regarding sql*plus, how to check that with a remote DB?
Button pressed too fast: How should PSD know anything about the correct parameters for my remote connection without an ORACLE_HOME? Any way to tell to PSD on the command line?
