Hello Team.
1. Sometimes in sql file with many SQLs, pl\sql blocks - when I try run particular query (even if it selected) - previous query is run. (queries separated by ";" or "/" (even for sqls)
2. Is it possible to add option to run sql always in read-only mode for the grid (result dataset)?
3. Is it possible to add supporting SQL Macro String recognition ? like q'[]' q'{}'?
4. In pl\sql developer when several queries are run - several tabs with result are created - are you going to add this functionality?
Thank you
Thank you
