A Aszarael Member Jan 10, 2008 #1 When we run a oracle pl/sql procedure using in/out parameters inside a Delphi 7 code we need to use it. So we need to know how to buit this method. For example: parameter in var1; parameter out var2; spr_teste(var1 in type,var2 out type); Any suggests? Best regards, Isael
Marco Kalter Administrator Staff member Jan 11, 2008 #1 Create a TOracleQuery with the following SQL: Code: begin spr_teste(:var1, :var2); end; Declare the 2 variables, and use SetVariable / GetVariable to set and get the values: Code: Query.SetVariable('var1', 10); Query.Execute; Result := Query.GetVariable('var2');
