Resolution resize - remote desktop problem
S. Studeny
we found some strange bug when PL/SQL Developer is used over remote desktop connection. This cause resolution to change from native 2560x1440 (PC) to 1600x900 (Notebook) and resize of all opened SQL desktop windows. Sometimes, windows with opened and fetched result set are not resized correctly. Resultset stay "behind"/"below" the bottom panel and there is no other way to get it out. Workaround is to open new sql window (every new SQL windows are opened correctly), copy SQL content from bugged window and paste it to the new sql window, but this is really annoying (when you have >20 windows per PLSQL dev instance).
vutdisk.php
