I want to use the "required" property of a database field (Oracle Not Null fieldproperty) in my Delphi application for adjusting controlproperties (backgroundcolor=yellow for required fields).
When I use an OracleDataset and don't use persistent fields I can read the Required property from the field. If the not-null status changes in the database, it changes in the application, which works fine.
BUT when I make the fields in the OracleDataset persistent (I have to when using lookupfields and calculated fields), the Required property becomes fixed. If the not-null fieldproperty in Oracle changes, the dataset still remembers the old status while I want to follow the real oracle-notnull property.
Is there a way of checking the "real" required (not-null) property in the database through the OracleDataset?
