This was by me:
You mentioned item 3 is ok, but I still can't see it in RC2 (Windows XP Pro SP 3).
Also, please consider implementing 1 sooner than later. I have to keep going back and forth between All and custom groups, in order to check which files haven't been added to that group yet. That makes it a pain to make the initial setup for each group. As we can move the file to the "None" group, maybe we could get a tab for that group.
Regards,
Gustavo
1. I see we have an option to move a file to group "None". But there is no way to see the files that don't belong to any groups.
2. "All" always has the focus when you open the Project Window. It'd be better if it kept focus on the last selected group.
3. The Project Search button doesn't have a hint.
Regards,
Gustavo
