martin_drescher
Hi.
I'm using PL/SQL Developer 7.1.5.1398.
I really like the PL/SQL Beautifier. But I don't like how you handle the using keyword in select statements. I looks like
A line break is inserted before using. I think in case of join ... using, the using should be on the same line as the join. This would be consistent with the formatting of join ... on.
Best regards
Martin Drescher
select *
from table1 t1
join table1 t2
using (some_id);
Best regards
Martin Drescher
