S sukhadukkham Member³ Aug 11, 2004 #1 tried to replace a couple of strings with option " selected text". searching is ok, but replace does not work correct
Marco Kalter Administrator Staff member Aug 12, 2004 #1 Works fine for me. Note that if you select "Replace", the currently selected text will be replaced. This may be the selection you intended as the scope! If you select "Replace all", then all occurrences within the selection will be replaced. If you select "Search next", you can then selectively replace occurrences. The original scope will remain.
