Remote Desktop issues with PL/SQL Developer
Jeff81
Anybody out there experience issues trying to remote desktop into their computer when they have multiple instances of PL/SQL Developer running on the remote computer. I do pretty frequent, and noticed if I close all or sometimes half of the instances I am able to remote in. I can't reproduce the steps on command to cause the problem but it does happen once a week.
When I try to remote desktop I connect to my computer and then it asks for my username and password and then it will attempt to connect for about a minute and then remote desktop will just close, no error messages nothing, not even in the event viewer. It might not be PL/SQL Developer causing the problem but right now it kind of seems that way. And I am running 7.1.5.1398 by the way. But I just install 8.0 so I will see how that works out.
I've used remote desktop to connect to a PC that is running PL/SQL Developer, and I've never experienced this problem. (XP Home connecting to XP Pro)
Is this perhaps a "simple" matter of resources? All your PL/SQL Developer instances could be using up so many resources that there are not enough left for remote desktop? When this happens again, I would start up a few additional instances of PL/SQL Developer to see if you quickly run into weirdness like missing toolbars/menus and/or error messages.
