REM-- causes ORA-00900: invalid SQL statement
Using 7.0.0.1050 Command Window
This is not a big problem, but it is inconsitent with SQL*Plus (9iR2 and 10gR2) and I abhor having to fire it up while I'm writing code.
In a script, if a line begins with "REM--" immediately prior to any SQL command, that command fails with the ORA-00900. For example:
REM-- Any text
create table xyz ( pdq number );
I ran into this while fiddling around with utPLSQL 2.2 - which has a script that has this syntax. I just bought PL/SQL Developer (and Love it) so that is why I bring this issue up.
Michael O'Neill
Clever Idea Consulting
The problem is caused by the REM-- expression. If there is a space between REM and --, it works okay.
We'll fix it.
