Hello
This is starting off pretty cool, but there are still some blockers that will prevent adoption.
Downloaded the trial version of the release of plyxon (1.0)
Performance on Mac M2 - While greatly improved, is still laggy. Especially when viewing large package bodies and the file open dialog is slow to render as well as the settings dialog.
Still no code completion after owner - e.g. I would expect code completion for owner.
Unable to open *.tst files - this is the exension pl/sql uses for test scripts. plyxon will only allow *.sql files to be selected in the open dialog. Probably could rename the extension to work around, but not ideal and then that will "break" the files for pl/sql. Maybe I'm missing something here?
No view option for packages - just edit
Schema Filter hangs the app - Attempting to use the filter function causes the application to hang for several minutes the first time, then seems fine after that. Also, it seems to implicitly use wildcard when filtering. Not a huge deal, but with large schemas a filter for specific package displays numerous records that contain the filter keywords in addition to the package I'm looking for.
Thanks!
Thanks!
