Recall sql
ScottMattes
Something was definitely wrong this morning. One of the SQLs that I was running yesterday isn't in the recall list. To be sure I removed the named sql plugin and tried again - it isn't in the ctl-e list. I then executed it again and checked ctl-e, not there.
Under what circumstances isn't a query put into the recall list? This query has some 'select stuff from tables where this is true' in the Select field list, but otherwise isn't extra-ordinary.
I thought that I had heard that somewhere.
If it hasn't been added as an enhancement, I would like
a) for the short term, i'd like to be warned when a SQL isn't being saved due to the size limit
b) in the long term, I'd like SQLs to be saved regardless of size
Thank you
