Recall of SQL Statement
msalhab
Good Mrng,
PLSQL is not recallling the SQL statements from the PLSRecall.dat
file even though the fill still under appdata\roaming\...
is there a way i can recall the SQL from this file.
Can you let me know exactly what goes wrong? Note that only successfully executed statements are added to the recall list.
Can you also go to Tools > Preferences > Tools / Recall Statement and check if any options have been set there?
