Quick Select Execution in SQL Window
Lucky-B
In the SQL Window, most of the time I enter more than one select statements. Is there (or can you add) a "quick" way of executing only one of the select statement (regardless of highlighting it)... Suggestion we put the cursor on part of one of the select and press Shift-F8 to execute instead of F8 to execute the complete SQL Window ? Thanks.
Lucky-B
Hi Lucky-B,
There is an 'AutoSelect' checkbox on the SQL Window tab of the Preferences.
Kind Regards, Mark.
Hy,
to this way, you had to add a ';' to every statement, like this:
SELECT 1 FROM dual;
SELECT 2 FROM dual;
Thanks for helping & looking
TenGor
