Question to SQL window vertical splitter position
Claus Pedersen
From the PLD 13 beta page: "The vertical splitter position is now preserved if manually moved."
I can not spot the difference in functionality from version 12. Which vertical splitter, the one between the columns?
OK, but how is the new behavior different from version 12? In version 12, the splitter also stayed where I put it, even after requery.
It is now preserved as the default splitter position for new SQL Windows when you select "Save Layout" from the "View" ribbon.
OK, I see.
But I still can not get it to work.
In SQL window, I execute a select that returns a couple of rows. The splitter between the select pane and the result grid is by default placed approx. 1/8 of the screen height from the top.
I now place the splitter at approx. the middle of the screen and save layout.
I open a new SQL window and execute the same select again. The splitter is back at 1/8 screen height.
I close PLD, open PLD again, new SQL window, execute same select, same position of splitter = 1/8 of screen height.
What should I do to get this to work?
