question about TOraclePackage function and object call
Hello;
I'm working with dbms_debug package and I'm using TOraclePackage.
I've two question about usage of TOraclePackage.
1)
By using TOraclePackage, how can I call and read the following Oracle Object.
TYPE xxxx IS TABLE OF VARCHAR2(64);
2)
on dbms_debug package there exist
FUNCTION CONTINUE
( run_info IN OUT runtime_info,
break flags IN BINARY_INTEGER,
info_requested IN BINARY_INTEGER :=NULL
) RETURN BINARY_INTEGER;
Using PL/SQL I could call this function as the following
dbms_debug.continue(
xxxx,
yyyy,
0 +
dbms_debug.info_getlineinfo +
dbms_debug.info_getbreakpoint +
dbms_debug.info_getstackdepth +
dbms_debug.info_getoerinfo +
0);
Above PL/SQL calling style, because info_getlineinfo,dbms_debug.info_getbreakpoint,dbms_debug.
info_getstackdepth and dbms_debug.info_getoerinfo are PLS_INTEGER datatypes. I read that
"PLS_INTEGER datatypes have the same range as the BINARY_INTEGER datatype, but use machine arithmetic
instead of library arithmetic, so are slightly faster for computation-heavy processing.".
In this case how can enter the following value
0 +
0
of parameter info_requested using TOraclePackage.
Is the following approach is true. On Delphi,the following summation produce correct result as PL/SQL function call mechanism?
0+
OraclePackage1.getParameter(info_getlineinfo)+
OraclePackage1.getParameter(info_getbreakpoint)+
OraclePackage1.getParameter(info_getstackdepth)+
OraclePackage1.getParameter(info_getoerinfo)+
0
If not how can I do this? Or is there any way for OraclePackage1.CallIntegerFunction to pass this summation using following
0 +
0
without any change?
Sincerely
Cagatay Ozpolat
This is not possible with the TOraclePackage component. It only supports scalar data types. You can use the TOracleQuery instead, or use the Package Wizard to generate a class to encapsulate the package.
