ScottMattes
Didn't there use to be a Preference for setting Date columns to output date and time? this is the first time that I have done much SQL Window queries and the date field is only showing the date portion. In the Command Window I see the date and time. I just went through the Preferences twice and do not see an option to make date field display both date and time. I did not see anything in the user's guide.
OK, wait a minute. I just opened a SQL Window (I had been in the results of an Execute SQL while debugging) and now I see the Date and Time format that I set in Preferences / NLS Options.
OK, so there is a bug in the Execute SQL while debugging window - it doesn't follow the NLS Options settings.
