Querys using sys.all_synonyms and sys.all_objects ??
rtsaito
Sorry if this a newbee question, but I did a search on the forum and could not find anything about it.
Does anyone know if this query is used by pl/sql and when? My problem is that it takes a lot of the oracle cpu cycles and goes to "internal lock wait".
Thanks.
select s.synonym_name object_name, o.object_type
from sys.all_synonyms s,
sys.all_objects o
and o.owner = s.table_owner
This query is executed when you open the Synonyms folder in the Object Browser.
hum... is there any way to disable it or minimize the impact on the database?
We just downgraded some of the machines to olders versions of pl/sql and the problem disappeared on those machines.
thanks!
This query responds instantaneous when I try it. Maybe the Oracle Dictionary tables need some tuning in this database instance? Maybe some dictionary index was dropped?
found this topic by forum-search, and just wanted to bring it up again.
i have a similar problem. this query is always running (and using LOTS of cpu und logical-reads) as long as i have an instance on pl-sql-developer open, and is not restricted to its own session, but seems to pop-up randomly on sessions of other users.
when i snipe such a session, it continues to run on another available session, not matter who the owner of the session is. (at least the enterprise-manager shows it that way).
as soon as i close all instances of the developer, this query vanishes.
this happens since the last update. any ideas?
another update:
the problem occurs here:
i tried some variations:
where s.owner in ('PUBLIC') -- fast
where s.owner in (user) -- fast
where s.owner in ( 'USERNAME' ) -- fast
where s.owner = user -- fast
where s.owner = 'PUBLIC' --fast
where s.owner = 'USERNAME' --fast
without owner-clause at all -- fast
where s.owner in ('PUBLIC', 'USERNAME') -- not ending
where ( s.owner = 'PUBLIC' or s.owner = user ) -- not ending
etc...
i'm confused.
We could change the query to a union to fix the problem in your case, but there is definitely something wrong with your dictionary tables or views.
We are experiencing a similar problem. When I first login to PLSQL Developer I can see on the database an ACTIVE session executing the following SQL:
sys.all_objects o
where s.owner in (:"SYS_B_0", user)
and o.object_type in (:"SYS_B_1", :"SYS_B_2", :"SYS_B_3",:"SYS_B_4", :"SYS_B_5", :"SYS_B_6", :"SYS_B_7")
This is also on the OS server side as a session using at least 16% cpu time. I know you mention a data dictionary issue, but is there any other possibility it's the application causing this performance hit?
Does it help if you execute this query with "where s.owner = user" instead?
This query (which runs in a background thread) can be disabled if you disable the "Describe context" preference (Tools > Preferences > Code Assistant).
We have the same issue - have disabled the feature, but it is still being called out somewhere in the program..
Is there any way we can change this query with in our installation of plsqldev ? I saw that adding a rule hint made it come back much much faster.
Thanks.
