Query Automation, pls help
I have PL/SQL Developer
I am trying to run about 30 queries and have the results exported to my hard-drive in a csv format. Is there any way to do this in either PL/SQL Dev or another program? Thanks
This is not possible in PL/SQL Developer. Our Query Reporter freeware utility can do this though. It requires that it is launched 30 times for these queries, with corresponding command-line parameters to save as CSV.
It can indeed save (export) the result set in CSV format. Interactively you can do so by pressing the export button.
On the command-line you can specify the CSV parameter. For example:
queryreporter userid=scott/tiger@chicago exec=C:\Temp\report01.rep csv=C:\temp\report01.csv hide
