Q: Owner of pacakge/prodcedure missing from code
Hi ,
maybe this issue which was discussed in the past (i tried to search but I havn't found)...
When I open code object (package,procedure..) in the editor . It doesn't add the owner name before.
for example create or replace testme ...
instead of create or replace scott.testme...
Is it possible to do have this (may as configurable option).
I need it , because all our install script are running from the same user (admin user).
I know we can use alter session set current schema ...
But this will required more work because we have a lot of schema.
Thanks amihay.
