Project Open Item inconsistent
zakko
There is an inconsistency how packages are opened for saving them into a project and how the same packages are opened from within a project as project item:
1. Open a db package with "View Spec & Body" (right-click in object browser)
=> Spec and Body are opened in their own tabs.
2. Add this package to a project
3. Save project
4. Right-click in project items "open item" and open package
Observed behaviour: Only spec is opened, but is editable (at least the tab says so).
Expected behaviour: Spec and Body should be opened in their respective tabs, not editable.
Generally, the expectation would be that the "opening state" (like opened via "View Spec & Body", "Edit Spec & Body", "View" or "Edit") is stored for further use as a project item too.
