hellraiserTG
Hello!
I have some projects with many different types of files stored in it. As to be able to make/build them by differnet steps I created some groups and put the corresponding files into it. But when I tried to sort the files in the groups per drag'n'drop (as you can do in the standard "All"-group), the result in the groups is very unpredictable
After several tries I found out that you can only change the display-order in the "ALL"-group and according to this sorting-order the files will magically rearrange themselves in the other groups
Is there a possibility to have an own sorting-feature per group? Would be very helpful!
Many thanks in advance!
Tom
Tom
