Would be very nice to have functionality for exporting user objects directly from project - items that are in the project should be pre-selected in "Export user objects" window. Also would be great to be able to use some kind of templates for building "export user objects" script: in many cases there is a need to add some pieces of SQL script to the generated file (usually - in the very beginning of it, sometimes - in the end). Would help to automate deployment scripts creation a LOT.
Thank you very much for the excellent product!!!
