Gytautas Member Jul 10, 2017 #1 If I load program file which initially had BOM in it no autodetection is needed whatsoever. Changed source code should be saved to the same file with BOM regardless of fact that all character coding maybe the same as windows ANSI code page.
Marco Kalter Administrator Staff member Jul 11, 2017 #1 You can go to Preferences > Files / Format to enable the "Always UTF8" and "Save with BOM" option.
