procedure OracleCI.FindAliases does not correctly handle tnsnames.ora
procedure OracleCI.FindAliases does not correctly handle tnsnames.ora, if after the opening bracket there is a gap.
All of the following descriptions are lost.
DB14 =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP) (HOST = DB14)(PORT = 1521)
(CONNECT_DATA = ( SID = DB14))
DB15 =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP) (HOST = DB15)(PORT = 1521)
(CONNECT_DATA = (SID = DB15))
DB16 =
(DESCRIPTION =
(ADDRESS = (PROTOCOL = TCP) (HOST = DB16)(PORT = 1521)
(CONNECT_DATA = (SID = DB16))
You are missing some parentheses:
Should be:
(ADDRESS = (PROTOCOL = TCP) (HOST = DB14)(PORT = 1521))
