Problems with the latest installer
NDzubiel
I found the following problem:
a) The installation delete all entries with my Delphi library path
b) The OLD DOA installation was not removed.
c) The new files where copied to: C:\Users\nils\AppData\Local\Temp\Direct Oracle Access 412
d) But the Library path was set to "$(BDS)\DOA"
Nils
It works fine here. Note that "C:\Users\nils\AppData\Local\Temp\Direct Oracle Access 412" is just a temporary location where installation files are extracted and from where the setup is launched. After that you can select a destination directory ($(BDS)\DOA by default), and the setup will remove old files and will copy the new files.
Well, it always worked - just stopped with this
installer - no errors nothing. I created the installation
manually - from the temp directory - the correct BPL's
were already in place.
Nils
