Problems with logging in to db server in multi session mode
PL/SQL Developer 9.0.4.1644
Steps to reproduce:
1. Start new instance of PL/SQL Developer.
2. In logon pop-up press cancel.
3. From menu choose Session -> Log on... and log in to any server (foo@bar).
4. Open new command window.
5. On the status bar choose another connection (foo@baz) from Recent list.
6. On the status bar choose previous connection (foo@bar) from Recent list.
7. From menu choose Session -> Log off -> All.
8. On the status bar press asterisk to reconnect.
9. On the status bar choose second connection (foo@baz) from Recent list.
What's wrong:
PL/SQL doesn't reconnect to the second server (foo@baz).
If at this point one opens new SQL Window and chooses second connection (foo@baz) from Recent list, then asterisk appears in SQL Window allowing to reconnect. When this asterisk is pressed, then in the Command Window, connection would be established too.
Best regards,
Lukasz
