problems with debugger
jmueller
Currently I am testing a pl/sql package. Testing
in SQL*Plus I receive the correct result sets, using the PL/SQL Developer with the same values I sometimes get empty result sets.
I am using trial-version 5.1.3.704.
Is there anybody with the same problems?
I can only imagine that:
1. The procedure is called with different parameter values or types.
2. You are using a different Oracle user.
3. SQL*Plus and PL/SQL Developer are on different PC's, or in different Oracle Homes on the same PC, and these 2 configurations have a different NLS settings.
4. The result relies on a package state (global variables) that are sometimes different or reset after a disconnect.
When I get those problems, it is because I am doing things in multiple windows, I have multi session on, and forgot do a commit in one of the windows(=sessions).
Hope this helps.
Hakuna Matata,
Arnoud.
