Problems with Cashed Updates
mczk
If I set OracleDataSet.CachedUpdates := true, I receive error "Cached updates requires a rowid!"
To avoid this error I added to the oracle table the field "id" with type "rowid".
The error disappeared, but I received the error: "ORA-03120: two-task conversion routine: integer overflow"
What am I doing wrong?
McZK
You can suppress your column ID of type rowid, it is not the solution.
In your query, simply add "rowid" amongst the columns list, like here :
select t.*, t.rowid from MY_TABLE t ...
ROWID is a system "virtual" field which represents the physical address of any Oracle record.
Phil.
