Problems under heavy usage
ctiedeman
We have numerous MIDAS applications that work under a fair amount of requests. However, we recently deployed one that sometimes gets hit several times a second and it locks up about once a day. Below are the conditions that occur:
Error: TOracleSession.LogOn request doesn't return.
Effect: The database logs a successful login, but the application just hangs waiting for the LogOn call to return. (code never reaches the next line)
Error: Access violation at address 60B5FF3A in module 'oran8.dll'. Read of address 00000000
Effect: All requests to the COM Server freeze upon entry and we have to kill the server PID before it will function correctly again. Before, we surrounded the LogOn call with a mutex, and that seemed to solve the problem until now.
Error: ORA-12533: TNS:illegal ADDRESS parameters
Effect: That request errors out, but other requests continue to function. (not a major problem, just annoying)
We are using Oracle 8.1.6 and DOA 3.4.3 on NT4. Any help would be greatly appreciated.
TIA
Can you verify if there are any user dump files on the database server that might correspond to this error?
