problems starting PSD 7.1 - network install
My company has PSD 7.1 installed on a networked drive. I can start PSD with an shortcut that points to the location of the .exe file.
I have set up the associations so .sql files should open with PSD, but when I click on a .sql file, PSD 7.1 starts but the .sql file is not opened. Instead, I get PSD with no windows open and a windows error popup saying "Windows cannot find '. Make sure you typed the name correctly, and then try again. To search for a file, click the start button, and then click search".
If PSD was already open, then the test sql file is opened in a new SQL window.
Has anyone seen this before? I'm sure it must be something with my machine since others here do NOT have this problem.
I've included the info from help | support info below
PL/SQL Developer
Version 7.1.1.1339
41473 - Unlimited user license
Physical memory : 1,038,404 kB (147,828 available)
Paging file : 2,503,356 kB (1,780,032 available)
Virtual memory : 2,097,024 kB (2,017,660 available)
Parameters
\\shacsql1\psd\plsqldev.exe
Preferences
Session mode: Multi
OCI Library:
Use OCI7: False
Preference Files
\\shacsql1\psd\Preferences\Default\New.ini
\\shacsql1\psd\Preferences\pmuller\default.ini
Plug-Ins
*Browser Extender version 2.0 by Joachim Rupik (\\shacsql1\PSD\PlugIns\be.dll)
*Comment lines v1.3 (\\shacsql1\PSD\PlugIns\commentline.dll)
*FTP File Interface 1.1 (\\shacsql1\PSD\PlugIns\ftp.dll)
*PL/SQL Documentation (plsqldoc) (\\shacsql1\PSD\PlugIns\plsqldoc.dll)
*PL/SQL Developer Scale Plug-In version 2003/11/13 (\\shacsql1\PSD\PlugIns\Scale.dll)
*Version Control Interface 1.2 (\\shacsql1\PSD\PlugIns\VCS.dll)
(* is Active)
Aliases
Homes
OraDb10g_home1 (C:\oracle\product\10.2.0\db_1)
OraHome92 (C:\oracle\ora92)
DLLs
C:\oracle\product\10.2.0\db_1\bin\oci.dll
TNS File
C:\oracle\product\10.2.0\db_1\Network\Admin\tnsnames.ora
Using
Home: OraDb10g_home1
DLL: C:\oracle\product\10.2.0\db_1\bin\oci.dll
OCI: version 9.2
Thanks for the reply Marco.
I'll ask to find out if we have any plans to upgrade our install to 7.1.4.
In the meantime, do you know of what may be causing this odd behavior? In our office, I am the only one experiencing this error even though we are all sharing the same network installation.
